Used this to determine the next block is arriving. in the robo program this is the trigger to measure the next color brick.
Mit dem Farbsensor könntest du mit Hilfe eines Triggersignales eine markante Farbfläche abfragen
fitec (18.12.2007, 14:59:48)
What des the Fototransistor do? What is its task?
Gruß fitec
rbudding (18.12.2007, 22:21:19)
To create a trigger event. After passing this point, the color sensor is switched on. after that point wait for a change on the A1 input, measure it and create a action, e.g. move it to the correct place.
