ft Halloween Skull structure
Hochgeladen am 30.10.2007, 18:02 von ft_idaho.  8 / 21
Schlagworte: Halloween, Skull, structure.
This is a rendering of the fischertechnik structure used for the Halloween Skull model.
(Dies ist eine Darstellung aus dem fischertechnik Struktur für die Halloween Skull Modell -google translation)
Parts List: 3 Hub Nut 2 Link 15 2 Motor Reducing Gearbox 2 Clip Axle with Gear Teeth T28 1 Hub Nut 11 Spring Cam 3 Building Block 15 with Bore 2 Mini Motor 6-9v 1 Building Block 15 x 15 2 Bottom Plate 30x90 2 Building Block 30 1 Building Block 15 3 Flat Hub Collet 4 Building Block 15x30x5 with Groove and Pin 1 Clip Axle 30 1 Axle Coupling 1 Clip Axle 75 1 Base Plate 120x60 2 Cog Wheel T 10 m=1.5 Narrow 1 Gear Wheel T 30 2 Angle Girder 120 2 Angle Girder 60 2 Rivet 4 1 I-Strut 45 5 Building Block 5 1 Building Block 5 with two Pins 8 Building Block 7.5 1 Clip Axle 180 1 Clip 5 1 Locking Worm m=1.5 2 Worm Nut m=1.5 4 Worm m=1.5 1 Angular Block 10x15x15 1 Building Plate 15x30x5 with 3 Grooves
